20 Most Recent Gemini PDT-6000 Turntable Questions & Answers
a new turntable is needed
Gemini PDT-6000... | Answered on Oct 16, 2009
HELLO!
I don't think the problem is the actual stylus (needle), it sounds like the magnetic cartridge has become faulty in some way (it does happen). My advice is try another cartridge and stylus (borrow if you can). If the audio stays the same then it MAY be the wiring in the arm going through the plinth (deck) and these wires terminate to pins or a small pcb board in the turntable where the phono cables and arm wires are connected. There may be a bad connection inside.
Also, make sure your tonearm counterweight and anti-skate are set up properly as well as this can have an effect on audio.
I hope this helps as I have been into audio since I was a kid!
Gemini PDT-6000... | Answered on Oct 14, 2009
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Gemini PDT-6000... | Answered on Aug 11, 2009
HELLO
I have just posted a cure for this deck, it is to do with the microswitches under the speed select buttons - they need to be replaced. Just repaired mine today - now there are no more problems selecting speeds.
If the speed goes back to 33 when the deck is switched off, this is because 33 is the default.
ALL THE BEST!
Gemini PDT-6000... | Answered on Jul 31, 2009
Much depends on the noise and where it is originating. The deck doesn't seem well thought of and it is unlikely the manufacturer has a spare parts service - unless you have the skills needed to locate and rectify the "noise", which could be electrical, electronic or mechanical, and otherwise restore the deck it would seem advisable to replace it.
Gemini Audio... | Answered on Jul 16, 2018
It is replaced with an LED. Any Disco supplies store should be able to advise. Similar to the Technics SL1200 series.
Gemini Audio... | Answered on Jun 05, 2018
Fixya is unable to suggest sources for Gemini dust cover hinges.
Gemini Audio... | Answered on May 28, 2018
Fixya does not sell Gemini parts.
Gemini Audio... | Answered on Mar 24, 2018
Gemini PDT-6000 Turntable Logo
9 questions posted
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Vernon Taylor
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Audio Players & Recorders
Most Popular Question
going from 45 33
  • Audio Players & Recorders
