Sharp XR-10X Multimedia Projector Logo
Posted on Apr 07, 2009
XR-10x bulb timer has timed out. How do I reset the projector?
I have replaced the bulb but the projector still will not turn on. indicator lights come on but no fan or power to the bulb.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1808
Points
7
You need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
1helpful
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
1helpful
I have replaced the lamp on my sharp xr-10x L. I cannot get the bulb to turn on I have lights so there is power but the lamp is not on.
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
3helpful
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
3helpful
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
1helpful
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
1helpful
No picture
ballast is not striking the lamp and needs replacing
2helpful
2answers
Does not turn on
the unit has an internal timer , this has happened to me several times  , i changed bulbs thinking that was the problem , when the bulb timer reaches 2000 hrs or the if you change bulbs and dont reset it the machine will not respond , check your manual and reset the timer
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
