20 Most Recent Sharp XR-10X Multimedia Projector Questions & Answers
2answers
My projector xr-11xc does not power on after it has been plugged in
Please check the internal fuse. It should be right underneath the power plug port. If it's broken, then buy a new one.
1/16/2019 12:48:35 PM • Sharp XR-10X... • Answered on Jan 16, 2019
0answers
Reset password
Be the first to answer 12/19/2015 9:50:54 AM • Sharp XR-10X... • Posted on Dec 19, 2015Be the first to answer
I am using Sharp multimedia projector XR-32S-L.There are white spots in the screen. What should I do to remove it?
white spot in image is comman problem of dmd chip it is fixed in to light engieen with heat sink replacment can possiable by expert
1/19/2015 6:47:22 AM • Sharp XR-10X... • Answered on Jan 19, 2015
2answers
Does not turn on
the unit has an internal timer , this has happened to me several times  , i changed bulbs thinking that was the problem , when the bulb timer reaches 2000 hrs or the if you change bulbs and dont reset it the machine will not respond , check your manual and reset the timer
10/20/2014 8:42:48 AM • Sharp XR-10X... • Answered on Oct 20, 2014
3answers
Sharp xr 10s no Power
blown fuse - take the lid off (six screws in the bottom and two in the back). look for a small red button by the lamp (front of the projector) and push it, it doesn't move much but it should work.
If that doesn't work call up 888-go-sharp their repair service.
NOTE - make sure you are NOT blocking the fan of the projector this causes it to overheat and shut down or worse... Make sure to tell your girlfriend the same thing so when you have the argument why she put the pillow on the projector you can at least say you told her not to block the fan.
10/19/2014 7:40:58 PM • Sharp XR-10X... • Answered on Oct 19, 2014
0answers
0answers
Display Issues-Sharp X-Flat Color TV
it should be in the setup menu..
2/2/2014 4:19:22 AM • Sharp XR-10X... • Answered on Feb 02, 2014
0answers
Factory reset
Be the first to answer 1/28/2014 8:20:47 AM • Sharp XR-10X... • Posted on Jan 28, 2014Be the first to answer
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp. Use a clean piece of toilet tissue when installing the new lamp to eliminate the above. Good luck!
1/11/2014 5:25:50 PM • Sharp XR-10X... • Answered on Jan 11, 2014
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
7/1/2013 5:49:26 AM • Sharp XR-10X... • Answered on Jul 01, 2013
0answers
Lamp keeps cycling on and off.
the circuit is closed somewhere it shouldnt be
4/13/2013 8:52:38 PM • Sharp XR-10X... • Answered on Apr 13, 2013
My Sharp XR-10x has no power or lights. Has worked
if there are no leds lit, the bimetal breaker has probably tripped. remove the top case (6 screws on the bottom and the top 2 on the back). find the red button on the front of the lamp housing and press it. if it clicked, it has reset and will now work. if it didn't, you have a bad power supply. while you have the projector open, blow the dust out of it with canned air.
2/26/2013 10:21:58 PM • Sharp XR-10X... • Answered on Feb 26, 2013
Sharp XR-10X Multimedia Projector Logo
136 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
am using sharp multimedia projector xr
  • Office Equipment & Supplies
