At a distance it appears ok heard I need to calibrate or send in for repair
First of all ------- Try changing the cable to another connector. If picture is still poor, try changing the cable for a new one. Also verify that the sky unit (or any other unit you are using )is giving a good picture by connecting it to another TV and see if picture is clear.
You could also verify the connections on the TV by inputting video from another source such as VCR or video camera.
if still the problem with new cables connected then ----
you will have to get it repaired because the IC component on the main board are got weak.and so the picture is getting worse slowly --- slowly.and later on it will get more damaged if not got repaired.so to avoid the damage get it repaired fist before further use.the cost of reparing will be negligible as its just a ic problem.and cost of single is near to $1 it depends upon how many ic are faulty.
but its worth getting it repaired.
thank you for using fixya.
