20 Most Recent
Sony Reader Touch PRS-600 Questions & Answers
My sony reader prs 650 is saying device locked,
you should not use other peoples computers to charge anything that has a processor or memory like the reader does.improper ejection from a pc/laptop can damage the software or hardware on the device, unlocking the device on the pc opens up a portal so the pc uses the device. this can damage the device if its not ejected properly. i.e ejecting the device though the pc. this stops the pc using the device safely so you can unplug it. you probably have corrupted a file on the reader. Im not to sure if sony still do the repair software for a pc to fix the device they used to on windows 7, if they still do it might be worth downloading the software and seeing if it can fix the device. all the best in your problem.
My sony reader keeps freezing.
sound to could a lot of things ... it could software issue or the ram or hard drive error that might make the system freeze up or lock up doing certain things. if you did all the hard reset and everything means all the junk was removed and you starting with like new reader..... but it had issues still... most companies have 1 year warranty on the product.. but you had it for 13 months and it has gone past.. only thing i can tell you might need to replace it with newest version 2017 to 2018 might be coming out now or soon WILL be that was way better than the one you got. you did all the things i would of try solving the problem but still had problems...i hate to buy something cause cost money i (me) would just have to face it get a better one do a lot research it to see how well went for other people. i hope this helps ya you did all the right try make it work. now it is all up to you on what you want to do.
Problems when syncing an Epub file and an Adobe
PDF to ePub Converter is a specific software for e-book reading devices users who want to convert PDF files to ePub format so that you can read .epub books offline on Sony Reader, BeBook, IREX Reader, iPhone, iPhone, iPod, iPad, and Nook from Barnes & Noble’s. Want to publish your own books or blog in .epub format? Just download PDF to ePub Converter to create ePub files.
Sony readers PRS 600 stuck
This happened to me. Reset would not work, nor would the on/off switch. Although the reader appeared to be 50% charge, I tried to charge it for hours and even overnight, but the charge indicator did not move. In the end, I disconnected the charger and abandoned the reader. The next day I looked at it and the charge indicator indicated 100% charge and I was able to switch off the reader and then use it normally. So it might be worth charging the reader even if you can't tell it is charging, then leaving it for a day and coming back to it. Worked for me.
Battery not charging
Means your battery is no good or the spot u plug ur cord in has went bad. Keeping on charge too long at some point could have caused this
It wont turn on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
Can i restart my sony psr e reader
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
