20 Most Recent
Olympus SP-500 UZ Digital Camera Questions & Answers
How do you restore bios
If your camera does act strange, it is just malfunctioning and you need to contact a service centre.
If there was a bug in the software, all registered users would have had a mail, for a firmware upgrade. I'm afraid there is not such a thing as restore bios.
The deepest restore, is reset settings in the camera to factory settings, but for that, your camera has to work normal.
What settings you can set back and how, you can find in your manual.
Wet digital camera
I have had a camera do this before and I left it in a bowl rice for about a week. Then it turned right on. Since rice will absorb the moisture we cant find or see. But I would make sure to take it apart as much as possible. :) Hope that works. GL
I cannot connect Olympus SP500 via USB port to
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
I have deleted photos on
Hi, I had a similar problem and solved it by formatting the card when in the camera, this will delete any old memory the card is retaining, hope this helps.
Camera wont turn on
1. Are you sure the battery is fully charged?
You can charge the battery by connecting the Olympus USB cable to the camera and computer.
Or using the delivered wall charger. When charging the orange LED on the camera should light.
When fully charged, the LED is off.
2. If this does not help you, check if your battery is well seated in the camera.
3. Check if the battery is faulty by replacing it by another one.
See users manual page 9, 12 and 53
I have deleted all of
Take memory card out and try to view any internally saved photos. If thats not it try formating the memory stick. Hope this helps.
Camera (Olympus SP500-uz) turns on,
Make sure you have the switch turned to "take picture (camera)" instead of "reveiw photos (green triagle)". On this one, i think it is a wheel on the top of the camera.
Only thing I can think of...
-Mark
We are trying to set up some product photos with a
1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken •
I want to put date
The program you're using to print the pictures should have an option to print the date either on the picture itself or in the margin (or maybe even on the back, depending on the printer). Check the documentation for the program.
Hello, My olympus sp-500uz has
Many people find it more convenient to just take the memory card out of the camera and put it in a card reader, especially now that these readers are built into computers and printers. That would be a "work around" for your problem.
As to the problem itself, a bad cable might be the cause, with damaged connectors. That is something you can replace cheaply (search Amazon on "Olympus SP-500 USB") so it won't be expensive to check it out.
Slow transfer might be due to using an older standard USB port. The first USBs were much slower than USB2 widely used now. Some older computers only have the earlier standard, and some have a mix of old and new.
