20 Most Recent Sharp R-930AK Convection/Microwave Oven Questions & Answers
Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
Best Manuals
Sharp R-930AK... | Answered on Mar 05, 2018
It's usually just the switch, and also be sure the damper door is not bent or blocked. We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
If you have other questions, please feel free to contact me directly (see below).
.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Sharp R-930AK... | Answered on Dec 01, 2017
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Sharp R-930AK... | Answered on Oct 09, 2017
The service manual is here: http://www.microwavecontrol.com/dcm24_r930ak_aw_sm.pdf
You may have a failed thermistor.
Contact me directly if you need more help.
pupista@gmail.com
Sharp R-930AK... | Answered on May 07, 2017
Just replace the fuse Brother. No harm done. BUT, keep it away from your wife. Maybe she's thinking doubling the voltage would make it twice as fast. NOPE!!!
Sharp R-930AK... | Answered on May 02, 2017
high voltage is blow due to over heatered..replace high high voltage fuse..
Sharp R-930AK... | Answered on Jul 16, 2016
check the door lever
Sharp R-930AK... | Answered on May 15, 2016
I'd try to unplug for a while. Could be a bad power cord for the microwave itself. I recently had a toaster problem. Bad wire right at the departure from the plug.
Sharp R-930AK... | Answered on May 12, 2015
It may be the thermistor, heating element, etc.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The manual has complete disassembly, test and part replacement info, as well as a very good troubleshooting chart.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Sharp R-930AK... | Answered on Mar 11, 2015
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sharp R-930AK... | Answered on Jan 27, 2015
grease that bad boy up
t-papa
Sharp R-930AK... | Answered on May 29, 2014
Sharp R-930AK Convection/Microwave Oven Logo
164 questions posted
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
sharp carousel microwave r930ak
  • Microwave Ovens
