If your GPS is bought in USA or Canada, it is impossible for the receiver not working. If you can't find a place in Canada, may be you can check again if the address you key in with the country "Canada" first. Some GPS needs you to put in the Country name first. Good luck.
You need to replace the map with a full map of the US and Canada. Did you register your unit with the Garmin website? Did you create an account? If so, you can log in and see if you can download a larger map. Otherwise you will need to purchase a new map. I can also help you with this issue but it would require for me to have your unit in front of me to do it.
At the top of the screen you'll see the country you're in i.e. Canada. At the bottom you'll see CHANGE COUNTRY. Press CHANGE COUNTRY and select USA. You should then be able to enter the USA address.
If that does not work check that you have a map of the USA on the satnav. Press TOOLS, SETTINGS, MAPS. At the bottom of the screen press MAP INFO and it will show you the maps you have. If the USA is there but not ticked press it to tick it and then it should work. If it does not show the USA then it's not on the satnav. I hope this solves your problem.
You don't say where you are. I'm presuming that you're in the USA and have a map of Canada on your satnav. If so press WHERE TO and then ADDRESS. When you press address the country it's set to is shown at the top of the screen. At the bottom there's a bar which says CHANGE COUNTRY (if you have a second country on your map) Press CHANGE COUNTRY and type CANADA. You should then be able to set Canadian addresses.
Hmmm did you put the 2010 map on it from garmin? I know when they first released this file there was a problem with it that did very strange things in parts of canada and the usa. I would recommend going to garmin's website and seeing if this is the problem. plug the device into your computer and see if it has a firmware upgrade it is ready for.
Hi,this will be dependant on the sd card and it,s maps database. if you have usa maps. this probably does,nt include maps of canada. check nuvis site, to see if canada maps are available for download or purchase.Mike @ Compurepair.
The Nuvi 350 comes with US, Canada and Puerto Rico. When you press Where To? and it asks State/Province, type a Canadian Province, such as Ontario. See what it asks next. It should ask for the City. Try Toronto. Then press Done twice. It should provide you with some addresses in Toronto. This should show it is mapping for Canada.
