It is a week now that my dish washer doesn't work. i called the technician and he didn't help me much. from what i read the problem is with the deactivete of the flooding valve. 1.Am i right? 2.Can i do some thing to fix it?
On several of models the water reservoir , the plastic house on the
left side must be cleaned, and the big hose in the bottom from
reservoir to the center is filled with fat so the water fills to slowly
and it runs over in the reservoir overflow hole and down in the bottom.
this , little by little fills up the aqua stop sensor system. This
causes water in the bottom of your machine and water block system to
trig..No not on hose but a float in the base of machine. Tilt washer on side
to drain water out of base allow to dry and should cure the fault 30
prob.
remember to disconnect from the mains electricity before doing this..also clean out any hoses connected to this...as the fats accumulate it clogs the lines and water slowly starts to fill in the bottom which activates the float and thereby triggering the fault .30code..this should save you a call out charge
.Hope this helps...please rate me...the Fang
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
