20 Most Recent AEG 23 in. Favorit 86070Vi Built-In Dishwasher Questions & Answers
Do you know what is error i10 ? I have same
AEG 23 in.... | Answered on Nov 29, 2017
Does the element get hot?
AEG 23 in.... | Answered on Jul 18, 2017
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
AEG 23 in.... | Answered on Aug 19, 2015
Please follow the instructions below:
re-attach-ceiling-spray-arm-favorit-puf5otocmioomqjajqjfrt2m-3-2.jpg Dado
AEG 23 in.... | Answered on Mar 16, 2015
As you realized, it is a small bolt blocked drain pump and therefore it is necessary to dismantle the drain pump and remove the bolt. You may need to replace it if is broken impeller. Access to drain pump is possible in two ways. From below and from the front side under the door of dishwasher. Be sure to disconnect the power supply voltage. Look the pictures.
Dado
AEG 23 in.... | Answered on Jan 04, 2015
Sounds like the control board alright, but often repairers witll just replace a board without identifying what caused the fault.
There could be a peripheral device that is causing the failure. I would replace the solenoid valve that allows the water to enter the machine and the control board. when the old board is removed it should be thouroughly checked for water marks or corrosion, all connecting cables to the control board should be checked for wear and corrosion and be recrimped if nessesary, when the new board is fitted its anchoring should be checked to make sure that it is very secure. lastly all ground/earth points should be checked.
Often removing the base of the dishwasher can help identify if there is a small leak, remember it onyl takes one drop of salt laden water to cause damage to these control boards.
Hope this helps :)
AEG 23 in.... | Answered on Oct 05, 2012
not heating aeg dish washer model 65011vi element found ok
AEG 23 in.... | Answered on Sep 25, 2012
check breaker panel, check door switch/latch
AEG 23 in.... | Answered on May 20, 2011
You will need to remove the drain pump/valve , look under to remove the unit as it will be clogged with food residue. You will need to flush out with jet of water and air and then check the drain valve to work in full strength. If not the water will remain within for more time than required as the program will sense an error.
AEG 23 in.... | Answered on Apr 27, 2011
Error 30 is an indication that the anti flood device has been activated.
As the machine starts up again when you tip it and drain the base this confirms that there is water getting into the base.
Pull the machine out, unplug it from the wall socket and take the side panels off.
You will have to run the machine with the panels off to look for the leak.
Please keep your hands (and the rest of your body) away from the machine whilst power is applied.
Once you locate the source of the leak, unplug the appliance from the wall socket before attempting to repair it.
Unfortunately, I can only tell you that the common leaks on these are from a loose nut on the salt container (take the cap off and check that the nut is tight) or from the wash motor hose.
Obviously, with the panels off you will be better placed to observe the leak.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
AEG 23 in.... | Answered on Apr 20, 2011
AEG 23 in. Favorit 86070Vi Built-In Dishwasher Logo
64 questions posted
Top AEG Dishwashers Experts
Paul Carew
Mike
Kevin
Kevin
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
AEG Dishwashers
  • AEG Dishwashers
Most Popular Question
aeg disherwasher will not switch no
  • Dishwashers
