most door handles have a screw in it from behind, or inside the door. so must disassemble the door to replace. check price before taking apart. sometimes very expensive plastic or not available.
Typically when tighten thedoorhandle of your Frigidaire microwave, I would recommend reaching out to a professional since you would have to remove the door and multiple layers to do so. Best regards! - Z
You need to remove the screws that are holding the frame of the door to gain access to the rear of the handle assuming that the handle is not stripped out to start with.
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
