20 Most Recent
Neff B7740N0GB Microwave Oven Questions & Answers
Sparking inside microwave door
There is exposed metal, when magnetron is running it will arc if there is exposed metal in the interior cavity which is more common, I have not seen this inside microwave door, inspect door carefully when you open it to see if there are bare spots. The manufacture use to sell microwave cavity paint to prevent this very problem, if this is not corrected it will short out the magnetron.
Hot air function not working
If it's not addressed in your owner's manual, you will need to take the cover off the oven to find and replace it.The owner's manual will also give you contact information for your manufacturer so you can contact them to find local or nearby parts distributors.
Light is broken in the microwave,
On most microwaves, it is easy to remove the shell or covers to gain access to the innards. Unplug power cord, and from the rear remove screws from shell and slide off to rear. The bulb is usually easy to change now.
