20 Most Recent
Electrolux ICON Microwave Combination Oven Questions & Answers
E30so75fps loose handle
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
How do you remove the
most slide to one side and pop off,try sliding both ways and pull out in the handle-mike
Handle broken off on model
handle for frigidair door . part # 530440323 black ond goes on stainless door . 127.98 . if handle is not broken but just came off maybe it can be remounted . ?? hope this helps **** ..
Difficulty cleaning Electrolux High Speed Oven
Most that say no oven cleaner have a self clean. If your does not. Take ammonia and wipe inside down and set a bowl of it inside over night. This will help a lot. One of my grandmothers tricks. It works great.
Please rate solution.
How to replace a light bulb in a electrolux microwave glmb 186
Unplug the microwave or turn off the power to the microwave at the breaker.
Locate the vent on your microwave. It is usually located on the front, side, or bottom of the machine.
Remove the screws holding the vent panel in place and take off the panel.
Lift off the vent panel of the microwave and set it aside.
Locate the box that holds the halogen light.
Loosen and remove the screws that hold the cover of the box in place.
Remove the cover to access the light bulb.
Carefully remove the old light bulb and replace it with a new one of similar wattage.
Replace the cover and screw it back in place.
Reattach the vent panel and screw it back in place.
Your user manual ought explain this in detail if you are unsure.
