20 Most Recent
Goldstar MV-1526 Microwave Oven Questions & Answers
I have a Gold Star
Hello, does the control panel light up? If it doesn't then probably the fuse has shorted. Now, if the front control panel does light up. There a number of thing going on. Door closer switch is working.
The mega-tron tube is shot or something is going on the micropressor. Now, if the mega-tron is shot. Buy a new micro wave oven and allways to recycle used appliances. GB...stewbison
Goldstar microwave burning
Toss it, when the electronics burn up it isnt safe to use anymore. Or especially with microwaves cost effective.
I can't get the sound to work.
You'll have to remove the cover to the microwave, MAKING SURE YOU UNPLUG IT 1ST. Check to see if it has a small speaker for the sounds to work. Take it to an electronics store and have them check to see if it works. IF NOT, replace it with a similar speaker (doesn't have to be exact, just the same voltage and ohms). If that isn't the problem, if the original speaker or device for sound works, then you've got a problem in the circuit board probably, and not worthwhile to replace it.
Microwaves
One of the door switches is bad, or the alignment is out, I recommend it be assessed for a more serious problem.
Microwave will not heat
If the microwave is 7 years old or less, there are too things that come to mind, defective magnetron, or the inverter board, cost should be considered when going ahead with repairs.
Goldstar MV1526W runs, turntable and fan turn, but
Thanks for mentioning the model number and detailed symptoms. That makes all the difference!Since the turntable is running, the most likely problems in this case are a failed magnetron or a repairable bad connection at the F or FA terminal of the magnetron.If there were a loud hum, that would also be either the magnetron or a shorted high voltage diode.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.htmlWe have also uploaded the service manual to our site
here to help you.Please note that the manual does not give you part numbers.You can get part numbers and order parts for LG / Goldstar products from
Encompass here
or you can call them toll-free at
866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Goldstar microwave GMV 1540TW locked
From the handy owner's manual
here:To set child lock:1. Press STOP/CLEAR.2. Touch and hold START more than 4 seconds."LOCKED" will appear in the display window with two beeps.To cancel child lock:1. Touch and hold START more than 4 seconds."LOCKED" will disappear in the display window with two beeps.
We're
advice and we'd appreciate your thoughtful rating of our answer.
