SOURCE: What is the factory setting for the throttle and
Workshop Manual for a Husky 357XP/359 (2006 - I will wager yours is similar) follows:
The Husky workshop manual on Appendix A (USA, this probably does not apply to your vintage saw) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles. There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move".
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix. I could not find an OM for a 1994, a 1995 says mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH.
Lou
