TP-LINK TPLink TLWA5210G 24GHz High Power Wireless Outdoor CPE IEEE 80211 bg Up to 50km Wireless Ra (TLWA5210G) Logo
Posted on Jan 09, 2013
I have the tp link 5210. in ap client router mode i find the network but local area connection says "no internet access"????
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
728
Points
Tp link 5210
Try to update the firmware.Here is the link TPLINK
Download for TL WA5210G V1
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    2helpful
    Connecting TLWR743ND to BT hub
    I spent ages trying to use tp- as an ap client. tried every setting I could think of. Then........ Changed wireless security setting on home hub 3 to use JUST WPA2 not WPA/WPA2 and all worked. Give it a go. :-)
    How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
    Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
    INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
    -> STATION Client/ /CLIENT ' Local/Lan
    or
    INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
    I just bought a TP-Link router. I was told to change my IP address because my internet provider's IP is 192.168.2.1 instead of 192.168.1.1. How do I change my IP address?
    Log in to router via browser at: 192.168.1.1
    At login and password promt enter
    login: admin
    password: admin
    Navigate from left pane: Advanced setup -> LAN
    Enter there you'r new ip: 192.168.2.1
    Subnet mask: 255.255.255.0
    Save
    How do I set my linksys WRT300N router to infrastructure mode vs adhoc mode? I have a magnavox blu ray player with wireless capability, it says I have to set my wireless router to infrastructure mode vs ad...
    http://compnetworking.about.com/cs/wirelessfaqs/f/adhocwireless.htm
    http://compnetworking.about.com/cs/wireless/f/infrawireless.htm
    Question: What is infrastructure mode in wireless networking? Answer: Infrastructure mode wireless networking bridges (joins) a wireless network to a wired Ethernet network. Infrastructure mode wireless also supports central connection points for WLAN clients. A wireless access point (AP) is required for infrastructure mode wireless networking. To join the WLAN, the AP and all wireless clients must be configured to use the same SSID. The AP is then cabled to the wired network to allow wireless clients access to, for example, Internet connections or printers. Additional APs can be added to the WLAN to increase the reach of the infrastructure and support any number of wireless clients. Compared to the alternative, ad-hoc wireless networks, infrastructure mode networks offer the advantage of scalability, centralized security management and improved reach. The disadvantage of infrastructure wireless networks is simply the additional cost to purchase AP hardware. Note that home wireless routers all feature a built-in AP to support infrastructure mode.
    3answers
    How to configure my tcp/ip TP-link access point
    The router has both a "WAN" (Wide Area Network) side
    and a "LAN" (Local Area Network) side.
    On the WAN side, most ISPs (Internet Service Providers) will provide the values for IP-address, subnet-mask, and gateway.
    On the LAN side, you should just use the "default" values.
    Connect your computer via an Ethernet-cable to the router,
    and the router will supply values to your computer,
    so that your computer can communicate with the router.
    12helpful
    Sitecom WL-330 range extender with dlink dir-615- unable to use
    I am guessing you have XP or vista. here are the instructions for both.
    XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
    Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
    Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
    1helpful
    Use Netgear WGR614 as an access point
    Right, it won't work. The 614 doesn't have the software to make it into a BRIDGE or AP CLIENT. It can only be made into an Access Point, meaning it needs a wired connection INTO it.
    A TP-Link http://www.tp-link.com/products/product_spe.asp?id=36 WA501G costs under $40 and gives you the ability to go from wireless to wired. It takes about 15 minutes to set up, and will plug into your DVR's ethernet port to extend your wireless network. It's programmed by setting the mode, AP, CLIENT, BRIDGE, etc. We use them in areas where we want to extend a wireless signal for distances like across parking lots, but it also will work across a room or two.
    There are also wired ethernet extenders that use house wiring like the Netgear XE-102, about $80, that look like two wall transformers with ethernet jacks. You plug one into the router/switch and the other into the DVR.
    Carl
    Encryption
    The Access Point determines encryption. This is because the access point provides the path into the network. In infrastructure mode (all computers communicate through the access point) the AP is configured for 64- or 128-bit encryption. In 64-bit, WEP key 1 through 4 must be selected. In 128-bit, there is only one WEP key. The client computers must now be configured to the same WEP settings in order to connect to the network. If the WEP settings on a client are not correct, the client will show that it is connected to an access point, but no data can be exchanged, i.e.. no Internet browsing is possible, etc. 802.11b Ad-hoc differs only in that each computer must use identical WEP settings. There is no AP in the system to drive the WEP.
    Top TP-LINK Computers & Internet Experts
     Mikey
    Mikey
    Menachem Grossman
    Menachem Grossman
    Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
