MY DSP-A5 AMP HAS A STANDARD OUTPUT FOR AN AMP BUT TO DRIVE THE BOSE IT NEEDS TO BE CONECTED TO MY BANANA INPUTS THAT ARE FOR FRONT SPEAKERS SO MY SUB THAT IS WIRED TO MY BANANA INPUTS IS NOT WORKING LIKE A SUB IT'S WORKING LIKE A NORMAL SPEAKER
SOURCE: do I need special speaker wires to hook up bose
It comes with special connectors - not necessarily special wire.
You will need the Lifestyle Cables.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
SOURCE: Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
bose speakers logitech sub
