Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
paul_casera Posted on Sep 12, 2012
Fuse blown and how to open the unit
How to change the fuse
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Wont turn on
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
1helpful
Short Circuit in changing light bulb in KHMS147SS has caused the unit to power completely down. Is there a fuse?
Changed cd player,new harness. lost power to unit and a/c, clock
Dear,
the main fuse has gone blown off
please get it changed yourself by opening the fuse box situated under the bonnet or get it done from the workshop.
thanx
We have an Amana AMC6138AAS microwave/convection oven. I was cooking popcorn last night and opened the door before the timer stopped. When I opened the door the inside light and the control panel went...
Did you have a power failure? Could be an overheat situation. Try unplugging the unit, wait 30 seconds and plug it in again. This resets the unit as long as there isn't a breaker or fuse blown. If it is a power issue, the display should start flashing. Did you get any error codes?
4helpful
3answers
I have a Merlin 230T garage door opener which abruptly stopped working altogether. Could it be the fuse?--or any other suggestions.
There is a fuse in a Model M-230T and I have seen a service man change it.Now that the fuse has blown again, I want to change it myself BUT can't now find it!
Can anyone please offer a guide to changing the fuse?
No picture or sound on tv
This sounds like a power supply problem. Check for a blown fuse in the unit. If there is no blown fuse then the power supply might have a shorted or open component in it. Check for the blown fuse first if the fuse is not blown or it can not be fixed by changing the fuse then the next culprit is the power supply, you will have to have a qualified TV technician do this.
I hope this helps
Thank you
shuttle83
Power windows stuck (2002 Taurus)
You can open the hood and find the fuse unit of the car please change the fuse then try .
3answers
I changed my car battery and since then the DVD screen won't open ...
You may have blown a fuse when you changed to battery. You might want to check the back of the player for a blow fuse, you may also want to check your cars fuse panel.
Scott ZXP8 Eclipse cd mini hifi system
Was the fuse Blown?? check with an ohm meteracross the two prongs that you plug into the wall of course you gotta unplug it for this. It should read around 4 to 10 ohms depending on the type of power transformer is in the unit.. If it reads open then theres a fuse open or a bad power transformer. If its not open check the power supply for the proper voltage from the diagram. Good luck
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
