The doors lock when I open or close the door. It is too expensive to repair the electrical issues so I just want to disable the power locks. Taking out fuse also disables the interior lights and power seat so that is not an option.
SOURCE: 2002 BMW 325 - key locked in trunk
There are several suggestions out there on how to retrieve BMW keys from the trunk. Many of the ways I tried failed, and it takes 2 to 3 days to get a new key made up. In the coupe there is the center piece in the back seat that folds down. Then on the back wall there is material that will fold down that is held up with Velcro. Behind that you will find a rubber insulation that is mostly cut and looks like a door, but not all the way. Carefully cut the rubber to remove the piece. Now you will find a metal wall, but there is a large piece that is tack welded on. I got turned around and kicked it with the bottom of my foot and got 3 sides loose. Then a softball bat knocked the final side loose. Pull that out and trash it, the final barrier is the insulation that is held in place with plastic clips that can just be pushed down. After that you can a pretty large hole to work through and get the keys. Just put everything back in place other than the metal plate and you will never know anything was done.
SOURCE: Wnere is fuse located for door locks, power seat, and gas cap door on 90 lincoln town car?
dhmwv: your fuse box is located in the passenger's compartment under the dash to the left of the steering column.
SOURCE: 1995 honda accord door won't open.
you'll need to slide something into the window well and try to hit the latch
SOURCE: VW Passat 1.6l 2000 (UK) Electrical failure
fuses are usually in the glove box or under the drivers dash or under the drivers side hood either physically inspect every fuse by pulling them one by one or the aid of a test light and a good ground to the test light
SOURCE: Mk4 Golf. Remote locking, windows and interior lights not working
Maybe fuse number 6 is blown (check lefthand side of steerning wheel where all teh fuses are located - you must open the door)
