HP DeskJet 5550 InkJet Printer Logo
Anonymous Posted on Jan 12, 2018
Hp deskjet 5550 printing only a few lines per page
When I try to print from MS word, the printer puts out pages that only have 1-2 sentences per page. It is like trying to print a paragraph and it will print the 1st two sentences on the first page, 3rd and 4th sentences on the second page, etc. I cant seem to figure out what to do to fix this. HELP!
Lawrence Oravetz
Level 3:
  • HP Master 10,558 Answers
  • Posted on Jan 13, 2018
Lawrence Oravetz
HP Master
Level 3:
Answers
10558
Questions
Helped
2700406
Points
29284
The printer driver is corrupt. Uninstall it from the computer before trying to reinstall the driver. If you don't have the driver CD you can go to HP's website and download it.
3 Related Answers
Anonymous
  • Posted on Nov 17, 2007
SOURCE: Help
1st page prints perfect but the 2nd page comes out with very light and skipped printing.
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 11, 2008
SOURCE: HP Deskjet 5550
Here is a HP document on what causes the green (power) light to blink and how to T/S it:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00035263&dlc=en&product=71896
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 57 Answers
  • Posted on Nov 19, 2008
SOURCE: hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
HP Deskjet D2560
First step is to see will if it print a test page.
Go to Start, settings, printers. Right click on the printer, properties, print test page.If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
Try the self-test? I'm not sure on the 5550 printer, but do this:With the printer ON,
1. Press and hold the power button
2. While holding the power button, press the resume button 4 times
3. Release the power button
1helpful
How do I set the print order on my hp deskjet 5550 so the last page prints first through to the first page printing last? Thank you. e-mail: [email protected]
Go to the control panel, go to printers and faxes, click or righ click on your printer, choose printer preferences and look for the basicsr section.
On the "Page order" frame choose "Back to front" and then click Apply.
Deskjet 5550; Windows 7; Microsoft Office 2007; not printing
That is strange
Try changing the default to a different printer (Microsoft XPS Document Writer) see if it prints to it...
Then (If that works) try switching the 5550 back to default.
If that don't do it, uninstall thee printer, reboot and reinstall the printer.
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
thanks,
Hamedo
2answers
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Help
HP deskjet 5550 sometimes prints and icon reads Toolbox not available because printdriver is not installed
thats easy! HP has a bad habit of screwing drivers up! List here what operating system you have, and the exact,with any letters behind the 5550, model number here and I'll get the drivers. I have almost every drivers for windows for that particular printer
k24674
Grand Canyon Tech
Grand Canyon Tech
