Heater started blowing intermittent hot and cold air. The mechanic said the heater core was fine and that it was electrical. We replaced the switch unit which was what he suggested, but now it only blows cold air. What are we missing?
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
issue.
blowing cold?
They told me the water pump was bad 2 years ago, but can still drive it with no noise and mostly a problem just in winter. If I rev the engine or drive around in 3rd gear then the heat works. Also works better on freeway than around town. Problem is it costs a fortune to replace water pump since they had the brilliant idea to put it in the middle of the engine.
Did you check any & all fuses that have to do with the heater, blower motor, etc?
my 2011 jeep liberty heater is blowing cold air but heater core is hot
Heater not blowing hot air, front driver side floorboard is wet, and car overheats
the fan only blows on high speed and will not blow hot air, the front driver floor board is wet, and the car overheats after driving around hour and half. What do you thinks is wrong and how can I check myself the isssue?
