My kitchenaid refrigerator is working on the freezer side the vegetable side is not colding.The top vent is getting cool air nit cold .There is no air in the bottom vent what should I do to fix it ??
You need to thaw the ice which has clogged the passageway from the freezer to the refrigerator. To do this, you can turn off the whole unit for several hours and let everything thaw, or you can remove the panels and locate the vent(s). Melt the ice with a hair dryer, then reassemble the panels and restart the refrigerator. There is a small chance that the fan in the freezer has frozen up as well. When the refrigerator compressor runs, you should also hear a small fan in the freezer run. If not, you will need to do some investigating to find out why.
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
SOURCE: kenmore elite refrigerator
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
fan won't start by itself.
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
SOURCE: The refrigerator is running but not cooling
I did check the fan and it was not operating and checked the voltage to the thermostat it was good and replaced the stat. It is working now.
Thank you
Todd
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
