20 Most Recent
KitchenAid Superba KSRS27CN Side by Side Refrigerator Questions & Answers
My freezer works fine it's my refiidgator doesn't
Check that foods in freezer are not blocking the vent which allows cold air to refrigerator. Newer refrigerators have only one cooling unit in the freezer. Cold air must be free to enter the refrigerator section.
The refridgerator door won't seal propertly. We
It could be a bad seal or the door could be sprung without seeing it it is hard to tell. Check the hinges make sure door is properly attached. If it appears to be sprung try pulling on the top of door and pushing on bottom to spring it back into place.... Just not too hard.
How to release wheels to move
Is it possible for you to make a photo from the wheels, or can you add a link to the producer of your refrigerator, I think you must get there detailed informations
The doors of my KitchenAid Superba side-by-side
Go to
www.applianceart.com and get a refrigerator cover.They have magnetic and vinyl options. I believe the vinyl option will work best for you because it will protect the surface and cover the existing rust.These guys have lots of options available from solid colors to designs from artists and even stainless steel.Hope this helps.
I know this seems like a minor problem, but the
Welcome to
FixYa.
The fact of the matter of the doors being at different
heights is typically an indication the unit isn't level and can be simply corrected by way of screwing the legs/wheels up or down.
If you remove the grill below the doors you should see the wheels and the adjustment screws/bolts. #2 is the wheel, # 3 & 5 are the adjustment screws to raise or lower the unit.
i.e.
They are typically a 5/16" or 3/8" hex head/slotted combination. Try adjusting one or the other with small adjustments until you notice the two doors starting to level to each other.
Let me know how you manage and I'll try to help you in any manner i can going forward. Good luck.
Thank you for choosing
FixYa today.
Regards,
Macmarkus :)
Is not cold enough
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Coldheatman101
12/28/2010 12:03:27 AM •
KitchenAid...
Answered
on Dec 28, 2010
Freezer not cold, everything is
hi,
probably an ice dam. unplug it and put everything in another fridge.
take all the shelves and icemaker parts out of the freezer and in the back usually is an access cover that runs the length of the freezer depending on the model, try and and take that off. put a hairdryer in the door and check it every 10 minutes. if you cant get the cover off put the dryer in the freezer on LOW ONLY and bring the door shut so theres a few inches for air circulation. and check it every10-15 minutes, keep the hair dryer away from plastic parts, so its shooting straight towards the back. it may take a day without removing the cover but that might get you going. dont use sharp objects to remove that ice blockage, let if fall away. if its still acting up after a couple days of this call the repairman.
jm
Not cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator
