SOURCE: heater will not heat
If you dont smell any gas make sure that all gas valves between the heater and the main gas meter are open, and the gas valve in the heater is in the on position. Try cleaning out the nozzles that the gas comes out of. Sometimes they can build up with cobwebs.
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
SOURCE: I have a Laars Lite2 gas spa heater. I just
Check and make sure there is nothing fallen on the igniter or spider webs on it. Anything touching it can cause a problem. Make sure wire is not burnt going to igniter. Gas Valve will lock out after a time period if no Ignition.
SOURCE: Jandy Lite 2 LJ will not ignite
water is leaking down onto the burner putting out the heater????
SOURCE: getting a FL4 service code. hot service igniter
Thank you for posting your question here on Fixya.com.
Follow the two wires with inline fuses in them down to below the burner tray. The ignitor is at the end. Is it damaged or missing the metal tip? Check the fuses as well. You will likely find the fuses blown and the ignitor damaged. Replace both and you should be back to heated water in no time.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
