Dacor Preference SGM365SS Gas Cooktop Logo
mike davis Posted on Apr 17, 2012
Have T. cooktop, 4 burner, griddle and grill. Short occurred w spark when using grill. Arch had burned connector to glow igniter. install new igniter, fixed connectors. Now igniter glows but no gas
Thernador gas cooktop gct484GG.
4 Related Answers
MARLON KELLER
  • 111 Answers
  • Posted on May 30, 2008
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Doug Camburn
  • 122 Answers
  • Posted on Jun 15, 2010
SOURCE: after cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
meztang
meztang
  • 112 Answers
  • Posted on Jul 18, 2010
SOURCE: One of the burners on my Dacor 4 burner gas
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Anonymous
  • 43501 Answers
  • Posted on Aug 18, 2010
SOURCE: 10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Left burner not lighting
Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
All 4 electrodes spark when only one is turned on
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
A spark that causes a snapping noise when a burner is turned on.
heatman101
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • 0helpful
    Both burners turn on when only one is needed
    I just had the same problem- when I replaced the whole cartridge.
    I repalced the infinite switch- do the one that gets the hottest- or do both.
    It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
    This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
    good luck
    Top Dacor Cooktops Experts
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
