20 Most Recent Jenn-Air JED8230 Electric Cooktop Questions & Answers
Oven stays on
Stove will not turn off CHECK Temperature Control Thermostat If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective. Oven Control Board The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven. Relay board: Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT. : I offer free advice bcuz God is so good! oven relay board dacor-relay-board-92028-ap3851203_01_l-undefined-undefined-0.jpg oven start switch-undefined-undefined-2.jpg oven temp control thermostat-undefined-undefined-5.jpg oven thermostat location2-undefined-undefined-9.jpg oven-control-board-316207511-01462609-undefined-undefined-14.jpg relay board gas relat board-undefined-undefined-20.jpg
3/17/2020 4:51:57 AM • Jenn-Air JED8230... • Answered on Mar 17, 2020
Was useing all 4 elements and cooktop stopped working
The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advice bcuz God is so good! Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. 1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful. 2. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires. 3. Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective. 4. Repeat the step above for the terminals "L2" and "H2". 5. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced. 6. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance. 7. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed. If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the contrl BE SURE TO CHECK FOR A BLOWN FUSE AS WELL infinte switch_noheat_03-undefined-undefined-0.jpg infinite switchs stove-undefined-undefined-2_0.jpg fuse location oven fuse_ranger_17-undefined-undefined-5_0.jpg fuse module with words-undefined-undefined-9_0.jpg fuse oven fuse location3-undefined-undefined-14_0.jpg
3/17/2020 4:47:02 AM • Jenn-Air JED8230... • Answered on Mar 17, 2020
Jenn-Air surface cooking elements look rusty and ugly
they make a special cleaner - polish just for the "solid" type burners. it looks like shoe polish and will make the burners look like new again. not sure where you can find it online but go to your local appliance parts houseand they will know what it is your needing.
10/18/2018 7:18:57 AM • Jenn-Air JED8230... • Answered on Oct 18, 2018
A guest used the electric
if it has slightly raised sides or a fat drain let it heart up and then used water on the hot surface to steam loosen the crud you could put a bit of washing up detergent in the water ( just a few drops )to assist in breaking down the surface tension and release any grease The same as cleaning a BBQ plate before using it
11/18/2017 1:20:27 AM • Jenn-Air JED8230... • Answered on Nov 18, 2017
Element on burner side wont heat up.
Hi, For spares try Repair Clinic, go right to the bottom of the page, and there you will find your Jenn Air Spares. Kind regards David
10/14/2017 11:32:02 AM • Jenn-Air JED8230... • Answered on Oct 14, 2017
Jenn-aire downdraft electric heating problem
Be sure the control is set to F* and not C*. always unplug electricity before attempting to repair on any electrical appliance
10/2/2017 1:22:12 PM • Jenn-Air JED8230... • Answered on Oct 02, 2017
Heard a spark coming from
You have a short that trips the beaker .I would try a fan switch first .
8/7/2017 5:55:12 PM • Jenn-Air JED8230... • Answered on Aug 07, 2017
Cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
4/4/2014 11:51:12 PM • Jenn-Air JED8230... • Answered on Apr 04, 2014
0answers
0answers
0answers
manual
Jenn-Air JED8230 Electric Cooktop Logo
175 questions posted
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Cooktops
  • Jenn-Air Cooktops
Most Popular Question
voltage each side but burners will not
  • Cooktops
