20 Most Recent
GE 30 in.Profile JGP945 Gas Cooktop Questions & Answers
Need to remove the top of a JGP945BEK2BB to
after using the simmer portion a mini explosion occurs after about 10 minutes and the flame goes out. if other burners are on they also go out. only happens when simmer is on
Convert natural gas to propane
Hi, W/D here.
I can tell you how I have done a similar appliance. I contacted my local propane company. They had all of the orifices, and cross reference guides necessary to convert it over to propane and they did it for free. Contact your local company. If your's won't do it for free like mine, they can surely get you the parts reasonably, and provide further guidance.
Best regards, --W/D--
Please take a moment to rate this solution so that we may continue to improve in helping others. Thanks.
When I try to use
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hairdryer do try it out and be sure there is not and liquid in it and putelectrical plug again to test it. If you still have the same problem, replacethe Spark module with a new one.
Here below you will find theparts layout of your range for all the help you might need.http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
Clicking cooktop
Ours clicks when the igniters are trying to fire up the burners. Is something stuck? They start as soon as you turn the knob on and the next stop turns them off. Double check each knob to make sure you don't have a bad one.
Carl
Ignitors keep making ticking sound, all burners
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM •
GE Cooktops
Answered
on Feb 17, 2021
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
11/1/2020 7:28:10 PM •
GE Cooktops
Answered
on Nov 01, 2020
