20 Most Recent Amana AKS3040 Gas Cooktop Questions & Answers
2answers
All off a sudden my cooktop started to tick and
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/31/2022 7:25:41 PM • Amana AKS3040... • Answered on Aug 31, 2022
No matter which knob I turn on, all 4 ignitors spark,
There is no fix. This is normal. All 4 ignitors will spark but the gas will only go to the burner where the gas is active.
1/19/2015 4:55:32 AM • Amana AKS3040... • Answered on Jan 19, 2015
No gas coming out of any burners but they click
It could be locked, the valve could bed closed. r clicking is just an electric switch I would make sure the gas is turned on somewhere
10/2/2014 1:16:51 AM • Amana AKS3040... • Answered on Oct 02, 2014
What should the burner placement look like
If it's a four burner cooktop chances are there are two the Same one bigger and one smaller. Usually they only fit one way
6/11/2014 11:37:26 AM • Amana AKS3040... • Answered on Jun 11, 2014
manual
AKS3040 Gas Cooktop Manual
Amana CooktopsUploaded on Oct 24, 2013
Seized knob, won't turn
Get some rust buster and apply it to the valve stem liberally. Work the shaft in and out a bit to loosen the shaft. Let that rust buster sit on there a bit. Good stuff. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/27/2011 4:19:03 PM • Amana AKS3040... • Answered on Sep 27, 2011
I wish to replace the grills. Where can I
Looks like $56 bucks today
Note: Use the manufacturers P number to make sure you get the correct grates. They are called grates not grills. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/27/2011 4:14:43 PM • Amana AKS3040... • Answered on Sep 27, 2011
2answers
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
6/8/2011 11:08:10 PM • Amana AKS3040... • Answered on Jun 08, 2011
0answers
Clicks but does not does not igite
Hello, thank you for your post. It sound like your saying the burners are not lighting up. Most of the time this is just a simple fix. Next time you turn on your burner notice were the igniter sparks this part of the burner needed to be cleaned. You should be able to take the burner cap off and the burner use a wire brush to clean the surface area so the spark has good contact. Take notice also of the igniter you will need to change it out if you see any cracks around the ceramic housing.
Happy Holidays! Please rate me "4 thumbs" if this information was useful.
12/21/2010 4:54:35 AM • Amana AKS3040... • Answered on Dec 21, 2010
Cat spilled liquid causing igniter to continuously
The gas is delivering as you may already saw with gas manifold and pipes going to each burner. In every burner there is one orifice with a tiny hole. So you haven't mentioned what liquid but in any case we advice that you can disassemble first the manifold and clean it very well. You can use a small piece of water hose adapt it on one side and blow air in it and check if it coming from other end. Is the only way where it is cogged.
Here is the link with the parts of your stove.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167493
11/2/2010 7:25:14 PM • Amana AKS3040... • Answered on Nov 02, 2010
On occasion the ignighter on
From your description this problem is simple to understand and easy to fix. The wire harness has a loose contact from the sparking rod to the spark module. At either connection points the connection is loose so it sometimes make contact and sometimes not.
So you need to disassemble the unit by removing burner and the top unit so you will find the wires and spark module under top unit.
Here is the link with all above parts of your unit which will help you.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167493&diagram_id=1320529#d1320529
11/1/2010 12:35:45 AM • Amana AKS3040... • Answered on Nov 01, 2010
2answers
One of the automatic ignition sparkers stopped
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
9/10/2010 3:35:55 AM • Amana AKS3040... • Answered on Sep 10, 2010
One burner on gas cook to is not having gas flow through it.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/5/2010 2:58:01 AM • Amana AKS3040... • Answered on Sep 05, 2010
Amana AKS3040 Gas Cooktop Logo
49 questions posted
Top Amana Cooktops Experts
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Amana Cooktops
  • Amana Cooktops
Most Popular Question
seized knob won 39 t turn
  • Cooktops
