HP LaserJet 2840 All-In-One Printer Logo
Posted on Oct 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP 2840 All in one won't print color
My HP 2840 all in one won't print color out of any Word, Power Point or Adobe so far. I have checked supply levels - all good. Printed demo page in color. Printed supply levels in color. Copies in color. Totally rebooted printer, no luck. Help! Marla
  • wackyiniraqi Nov 07, 2008
    won't print color no matter what I do. has plenty of ink drivers good dunno what to do
  • Anonymous Mar 27, 2014
    This is a 2840 with only 28,000+ copies showing on the reports.
Orn Wilson
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Oct 20, 2019
Orn Wilson
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
73169
Points
203
The solenoid that controls the carousel movement is sticking throwing off carousel home position. The laser scanner beams are actually hitting the black plastic carousel instead of the cartridge drums therefore getting blank/or slight color pages with no error codes. This was an early color machine that didn't have the error code 59.xx (transfer belt movement errors) that is currently in the error code list for newer HP color printers. This solenoid is not that difficult to get to. Just remove the sticky substance (self explanatory once you get to it). When I clean these I used blue painter tape on the sticky areas when reassembling which works for me, but you can do whatever...just get the sticky off!!
Anonymous
Level 3:
  • Master 849 Answers
  • Posted on Oct 28, 2008
Anonymous
Master
Level 3:
Answers
849
Questions
0
Helped
315541
Points
2014
Printer is ok, check the connecting cable and drivers.
2answers
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
3answers
2answers
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
2answers
The hp color laser jet 2840 does not print. message "50.2 fuser error" appears
HP recommended checks: 1. adequate 120 VAC power supply, 2. Remove Fuser Assembly, wait 5 minutes and then reseat. 3. Reset the printer to Factory Default settings (remember to copy down the IP address, mask and gateway numbers first).
While this may solve the problem, it is much more likely it's time to replace the fuser. Cost is approx $125 if you buy it online. Just do a Google search on HP 2840 fuser.
This link will show you where your fuser is and how to remove and replace it.
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=445194&MEID=631309C6-088F-43F9-931F-604BAE10EB69
2helpful
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
1helpful
2answers
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
k24674
Grand Canyon Tech
Grand Canyon Tech
