SOURCE: Nortel IPSEC VPN unable to connect via a Belkin N1 Wireless Router
Belkin says IPSec pass thru works now. I'll know tomorrow.
http://www.belkin.com/contact/milan/default1.aspx?id=580959590B0A5E0C0B5A59575B595F0A305F5D
F5D8231-4 WW v4.00.18
http://www.belkin.com/contact/milan/filedownload.aspx?id=580959590B0A5E0C0B5A59575B595F0A305F5D&file=0
SOURCE: Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
SOURCE: I have a Belkin N600 router that works great.
Goto virtual servers under firewall in belkin router interface...
and forward these port numbers, for your computer's ip address...
50 both
51 both
500 both
10000 both
1723 tcp
1701 udp
Explanation:
Ports Needed for PPTP VPN
- TCP Port 1723
- UDP Port 500
Ports Needed for L2TP VPN
- TCP Port 1701
- UDP Port 500
Ports Needed for IPSec/ESP
- UDP Port 500
For screen shots and step by step explanation on how to forward ports click here....
Connect Router - Computer ( Wired )
Open Router Setup by typing http://192.168.2.1 on the address bar of the internet explorer
On the left Click on Firewall
Leave the password blank and click submit
Disable it and click apply changes
Check if it works
If it is not working then ..
Contact your VPN Client and get the port numbers (TCP And UDP )to be forwarded through the router
And if you get the numbers .. add a comment with the port numbers so that we can continue the troubleshooting
Tom
SOURCE: Belkin Play N600. Acer Vista laptop. Wifi only,
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
