Color cartidge was out, printer was shut off for a long period of time, possible shut itself down to protect print heads, how do you fix this
In most cases the printer driver software can have errors while being in use or is shut down.Also if the printer ink cartidges were replaced in the middle without the use of maintenance shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
If the cartidge was installed without the right sequence then it is possible that the software has errors. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.Hope the installed cartidge was the same type and model.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos with great quality.
I hope that this should resolve the issue for you.
You can mail me at [email protected] for further assistance, I'll be glad to help you.
Bye
unplugged printer several times
