I have a frigidaire above the oven microwave oven. It functions properly ie the turntable turns, the indicator lights work but it does not heat the food products placed inside,,bottom line it will not heat.
Since the light comes on and the turntable rotates, I would suspect a bad magnetron, a loose connection at the magnetron, a failed high voltage transformer, or shorted high voltage rectifier diode.
If it's less than one year old, it should be fully covered under warranty.I'd suggest contacting the manufacturer to get it fixed free.
Ifit's within the magnetron portion of the warranty (usually 5-9 years)but out of the original full warranty (usually 1 year), then yourmanufacturer will cover the part cost, but not the cost to visit you orthe labor charge to do the work.
If you or a friend want to work on it, please see these links first:http://www.microwavedisplay.com/safety.txt& http://www.microwavedisplay.com/disassembly.txt
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
For Frigidaire models, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can find your nearest Frigidaire/Maytag-authorized servicer here.
You can visit Daewoo onlineor call them at 1-800-323-9668 or 1-800-553-4355 to find parts or findyour nearest authorized service center to have them do the work.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Microwave Oven Basic Troubleshooting Tips
heatman101
I have a microwave oven, make Daewoo, model KOC-621Q and the microwave oven doesn't seem to be heating up. It makes the same noise, rotates and the light comes on but it doesn't heat up. The other grill element still works i.e get hots. Can you help?
I turned the oven upside down and see a loose screw and a loose round disk. How to I access the bottom to repair
