Acer AL2216W Black LCD Monitor
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors
pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
he can make you a set of caps for you.
Or www.digikey.com just make sure to use
caps with low ESR, 105c, high ripple current, long life rating such as
PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
SOURCE: HOW CAN I TAKE OUT THE MONITOR BASE FROM THE MONITOR ACER
remove the hinge cover, then remove the six screws you see there. Then the base slides out.
SOURCE: AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
SOURCE: Monitor comes up shows "acer" then says no signal and goes black
Acer Field Service Bulletin
DATE: 04/03/08 NUMBER: mn_029
SUBJECT:
REVISED - The message "No Signal" sporadically appears on the screen.
AFFECTS: X241 monitors ET.L990B.029
ISSUE:
This is an update to the document original published 9/19/07
While the X241W monitor is in use, it might show "No Signal" on screen abnormally.
Sometimes, the monitor may still continue to display video.
Other times the monitor may be go black. For some customers, the problem will correct itself in a minute. These problems often occur during the first 20 minutes the monitor is powered on.
SOLUTION:
Short term #1 – Unplug the monitor to reset the video controller.
Long term #1 - The main board firmware can be reflashed to a newer version of
firmware by an Acer authorized monitor repair depot. The latest firmwares are listed below.
for monitor with s/n version “00” and ”10” FW = WDTD-D1AP0 V1.03
for monitor with s/n version “12” FW = WDTD-D1SP0 V1.02
for monitor with s/n version “13” FW = WDTD-D2AP0 V1.03
ACTION REQUIRED:
Confirm the firmware has been updated prior to returning the monitor to the customer
or to stock.
When an Acer service repair technician updates the firmware, they should record that
the part IN-MONITOR was used.
SPECIAL TOOLS
6K.ISPVE.001 Tool Kit with a corresponding DB-15 and Serial data cable.
USB-A to USB-B cable for power.
PARTS REQUIRED
Replace main board if firmware update does not resolve the problem. See spares parts list for p/n.
SOURCE: my acer v223w lcd monitor screen when i pluged it
uninstall the driver from ur display in the device manager, u shud be able to do this thru safe mode. it seems the lcd driver is not compatible with thw m/bord
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
