20 Most Recent
Acer X241Wsd Monitor Questions & Answers
My monitor X241W flashes the ON/OFF LED, and
It may be in the safety shutdown mode if it sensing too much current draw. No short circuits in the inverter board. Plug it ino the wall out let and do not activate the power switch so the power supply will be running without having to power up the inverter board, if the 24vd is OK in the power supply then you may jave problem in the inverter board. How does the DC voltage on the secondary power supply side? Bad caps can look normal but it can have high ESR (Equivalent Series Resistance) which is a no no for switching power supply. Post back with more info. So far I cannot locate free service manual download for this model.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
My acer monitor
I have answered this in other threads but to reiterate....
The Gray rectangle "No Signal" I use a Power Strip and Turn off as soon as it cycles back to Normal screen. It is so much easier then to unplug and Plug back in when it does happen.
As for the Newer Problem(s) and I too have had mine for only couple of years... Copied from Previous post
This is not a Fix to the Problem, If you read some of the other
"fixes" that relate to this you will see that it is a more serious
problem and one that Acer should Do the Honorable Thing and have a
Recall.
I actually went in side on three of the Same Monitors and one that was
a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am
Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Monitor ACER 24" stop display after few seconds
Recall.
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
On startup monitor begins warm up for a second and
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
When turn on it flashes for about 1 second, then
this is probably a data problem...
try to access to monitors on-board menu (usually a small button beneath the screen)
if the menu comes up i would try in this order
a new vga cable
connected monitor to a different pc/laptop
wiggle your video card
try friends monitor on your pc
good luck, rate if useful
My monitor went dim and goes black after a few
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
