20 Most Recent
Acer AL1714 17" LCD Monitor Questions & Answers
Desktop icons appear as a shadow on all windows.
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Acer AL1714
HI again,
I think you will have to go for a repair but anyways i suggest you to ask the other experts.Like Irish druid or bestdarngood.
Too bright
Look for buttons on the monitor, there should be a menu button allowing you to select a bunch of editable settings, usually including a brightness setting.
Hi, My monitor (AL1714) is fine for about 5
Hi! Looks like the monitor is in stressed and can't stand long time use. Replacing these parts plus labor is like buying a new one for it will take time and the availability of the parts. I strongly suggest that you buy a new one which can cost you less. HOpe this helps and thank you for using FIxYa!
Acer lcd screen power button broke
Can you feel that it click when you push on it? It is a momentary type tactile switch that you can get from <a href="http://www.mouser.com">www.mouser.com</a> that you need to match the size and dimensions.<br />
You may have problem some where else.<br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
How to open the backcover
jorickfranke, A picture is worth a thousand words!! Or in your case, a "video clip" at YOUTUBE! ! ! Search This "lcd monitor disassembly" or "lcd monitor repair" I'm sure you will find out how to do it. Just don't use sharp cutting instruments for "parting" the rear cover from the "front bezel" of unit. Cost of repair increases 10 fold if trip to hospital "ER" is required.
Good luck. 12fixlouie
Screen is fuzzy
For best display on LCD monitor, you need to set the PC video resolution to the native resolution of the monitor, this monitor native resolution is 1280 x 1024 @60Hz.
Desktop has turned sideways
use graphic adapter options and you will see the key to change the orientation it is something like alt alt arrow key etc ..which you need to find in the adapter key settings..
My Acer AL1714 monitor was given to me, the person
mccampbell71 Probably a failure of inverter circuit(dc to ac 600-1100vac) to light-up (sustain) "cold-cathode-fluorescent lamps" causing the "switch-mode-power-supply" to go into full or partial SHUTDOWN mode. Black Screen of Death strikes again!!! The Question I have is why did you BUY a "black-brick" supply? Did the other one fall out of the car or get run over by a train? Only you will be able to make the decision of to REPAIR or Trade-in for new. You are no different than 5000 others worldwide (all brands) who have monitor's with BSOD! Yes, some (75-90%) can be saved to work 1-3 more years! Read some of my other responses in my profiles (12fixlouie aka louie12fix) to learn of the options you have open to you. Bye for now 12fixlouie If this info was of some use please rate on fixya.
Screen does not work
HI,
I am not a LCD Tv expert so my advice won't be of use to you.I suggest you to ask the same to Ginko or Benimur.
Lcd flashing
Check video cable and connection to computer. If the connection is fine, then this is either a faulty signal board, or a faulty LCD controller board.
Using my broken screen as a bedside lamp
More than likely it is drawing too much voltage, some of the older supplies would shut off after a few seconds if it was drawing too much,
the fix was to go into settings on the monitor and turn the brightness down, for you, you could put a resister in the line if you have no other way to adjust it.
I would also recommend not using one of these bulbs like that unless you have a way to protect it, they are known to contain mercury and several other very bad chemicals that will be released if broken.
