Refrigerators Logo
qasim ali Posted on Dec 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Medical instruments high condensation
Level 3:
  • Master 17,130 Answers
  • Posted on Dec 14, 2011
Master
Level 3:
Answers
17130
Questions
0
Helped
3635766
Points
52372
Please use some drying material including using a soft heater to ward off the moisture. You have not mentioned the fault or the product. Hang packages of chemicals that absorb moisture. Moisture-absorbing chemicals include silica gel, activated alumina, anhydrous calcium sulfate and molecular sieves.
Read more: How to Absorb Moisture ' eHow.com http://www.ehow.com/how_7860053_absorb-moisture.html#ixzz1K9SxCzZ9
I have a Thinline pickup in my 1924 0-28, because unfortunately nothing else is slim enough to do the job. I took it out of the guitar years ago after it failed onstage, and now I've decided to give it...
Probably the ground wire is broken on this either at the jack or very near the end of th pickup stick. This acts like a condenser microphone and is fairly high impedance so any break in the ground will pickup hum. Using a high impedance guitar cable is necessary.
2answers
WHAT IS TRILIPIX
Trilipix is mainly used to treat high cholesterol and high triglyceride levels. It is sometimes given together with other cholesterol-lowering medications.
2helpful
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
3helpful
My LG Artcool isn't working keeps flashin ch 61
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. kHnce remove the gas, flush out the system and vacumize and then do gas charging.
Samson
try using the instrument input lets see if its going to change something.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
