Had same problem -- tv was set to avi -2 --- change it to imput avi- 1 === works fine
Maybe there is an issue with the input you are using for the DVD player. Can you change inputs to the projector. Also there may be an autoformat option listed in the manual pg.23. It would be in the picture menu.
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Might help you to know that this was a sudden event, YC+V and DVD pkayer worked firn for 4 years until this week...
