20 Most Recent
RCA F27450 27" TV Questions & Answers
Need Remote Control For 1992 RCA TV Set
There should be access to the menu system from the panel controls. Either a menu button or pressing a combination of buttons for a certain period of time to access the menu.
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Tv wont stay on whats broke in it
if it turns off in the same amount of time every time, and can turn right back on, check your sleep settings... it is a feature that turns the tv off for you.
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
I have 2 black spaces on each side of my screen
The width of the picture is less than normal. It can be adjusted by entering in to its service menu options. But, entering service menu options and adjusting data values there is a skilled task. It will be best to contact any expereinced service techinician ot do this. Or Visit the site named 'Electro-help' for more details. Check this
link and select the site. View it in
'Flip card' option, which can be selected from the drop down box menu at
the left top corner or the display window. It will make search easy. If you are confident that you can do this, just proceed. If not, do not tamper the TV.
We have a Sony rear
The problem on your tv is the leaky electroltytic capacitor on the regulator section.
Replaced the capacitor on that area and your unit will be back to normal again.
If you don't have an experience in electronics find a qualified technician to do the job for you.
Have a nice day!
Thanks for using fixya.
JDVillanueva
16 in symphonic lcd tv
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
