20 Most Recent RCA Scenium D40W20 40" Rear Projection HDTV Questions & Answers
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
RCA Scenium... | Answered on Sep 19, 2019
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
RCA Scenium... | Answered on Oct 20, 2017
If your RCA TV is 14 years old, it may be nearing end of life. You may find repair is not worth considering.
RCA Scenium... | Answered on Sep 11, 2014
we layed it down to insert the brackets
RCA Scenium... | Answered on Nov 03, 2012
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. The noise is what gives it away. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
RCA Scenium... | Answered on May 03, 2012
Does the led blink
RCA Scenium... | Answered on Apr 10, 2012
If this is a combo unit (TV with DVD built in) you need the original remote---Universals almost always are missing key features the original remote had as most companies have someone else make the unit and put their name on it.
RCA Scenium... | Answered on Mar 22, 2012
See my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for help with troubleshooting.
Thanks for using FixYa and for the great rating.
hardrocko
RCA Scenium... | Answered on Sep 07, 2011
do you see thin curved blue lines going from bottomto top of screen. If so its most likley a blue CRT drive board issue. If its a solid blue it could be a small signal board issue.
RCA Scenium... | Answered on Aug 04, 2011
Hello
I can,t understand the fault of your TV with this short description. Will you please inform me some more details of the fault? What do you mean by this "image tears" and "inverted colour". Please give me some more explanations. OK.
RCA Scenium... | Answered on May 12, 2011
You have bad grounds on the power board. The first place are the solder connections under neath the flyback transformer. This is my first area of inspections. You must really, really inspect the rest of the board. This TV has many poor solder connections too numerous to pin point. These are very small and will take an extremely close inspection. I cannot say enough here. Look for bad solder grounds on the vertical IC (do not use excess solder or you will short this IC). Look for solder connections on transistors, diodes, jumpers, power resistors and capacitors. Capacitors include electrolytic, disks and safety capacitors.Resolder other transformers too. Be sure to check close for bad solder connections on the heat sinks as well. Next, use an ESR meter to check all your electrolytic capacitors.This is a good place to start repairs. Thanks for asking and show a few hands of support!
RCA Scenium... | Answered on Feb 08, 2011
RCA Scenium D40W20 40" Rear Projection HDTV Logo
116 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca hdtv not turn all
  • Televison & Video
