You mean align page not scanning/not completed?.if align page not printed properly due clogged nozzles, printer unable to completes align successfully, remove both cartridges clean nozzles as shown in attached link, refix & try, even not resolved replace faulty cartridge, or else when its performing the align printing cancel it,but every time when switch on the machine it will print align page..http://www.youtube.com/watch?v=0nWCTKPaBlo
SOURCE: My HP J5780 will not scan.
you document was place in a different direction, try to place the document in the right place and scan again.
hope this helps
SOURCE: unable to successfully scan alignment sheet
Dear Sir,
plzz follow this to solve your problem,
Do this, follow exactly and regulation. 1. Turn the printer off and wait 10 seconds. Turn it back 2nd Let printer to print the test page. 3. After the test page is printed, remove the USB cable connecting the printer to the computer. NOT turn off the printer while you disconnect the USB cable. 4. Place the test page on the scanner glass and press the Scan button on the printer. ON light will flash as the page being scanned. 5. Remove the test page when ON is lit. 6. Finally, to turn off printer and wait 10 seconds. Then on again. No more print test pages! Yay! (You can now connect the printer to the computer via USB cable.
Thanks For Your Time,
SOURCE: Nothing will print (Word, internet), except it
That means that the alignment is not complete. Please re-install the Ink Cartrdiges. And scan the Alignment Sheet properly.
SOURCE: cartridge alignment function repeats
you must replace both ink cartridges to get a sucessful alignment.
SOURCE: Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Solution by Vinay Kumar Kuchipudi
You mean align page not scanning/not completed?.if align page not printed properly due clogged nozzles, printer unable to completes align successfully, remove both cartridges clean nozzles......
