HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Anonymous Posted on Sep 27, 2011
The printer is not printing, ink is new - HP Officejet 6500 Wireless All-in-One InkJet Printer
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Sep 28, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
451184
Points
2591
Ink means cartridges? but what about print heads?..go to tool box perform clean nozzles, check if not satisfied do this process twice or thrice. check print quality if you found yellow or black missed replace left print head, magenta or cyan missed replace right print head.. part number on print heads..
1helpful
Hello . My Epson stylus c66 printer ,print but the paper is white.
Do you mean your Epson Printer Printing blank pages? The Epson printer printing blank pages due to wrong paper size, outdated printer driver, Empty ink cartridge, dirty print head, improperly installed ink cartridge, and more.
Follow the steps to fix the Epson printer printing blank page issue:
·Restart the printer
·Fill the empty ink cartridge and reinstall the new ink cartridge
·Update printer drivers. If you have done all the above steps but still the printer printing blank pages.
Then follow more steps to fix the Epson printer prints blank pages issue.
1helpful
2answers
The printer doesn't print all the in their entirety. Some lines are fine but many are not.
Think you need a new print head which is a component in your printer. Canon ink cartridges just contain ink. HP, on the other hand, have ink cartridges with the print head built in to the ink cartridge so that every time you buy a cartridge you basically have a new printer.
1helpful
2answers
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
2helpful
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
2helpful
It is not printing using black ink. I have
Sounds like your black print head may be clogged. You can get a new one from Precision Roller for $60. Another fact that would confirm that your print head is clogged is if you let the printer sit for more than a few weeks without printing with it.
http://www.precisionroller.com/k_canon_pixma_ip90_print_head/m114d7411c104/
Bought new ink but photos arent printing.
It is more than likely the print head itself. It seems to be a problem with these printers.
2helpful
2answers
Ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
3answers
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
1helpful
2answers
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
k24674
Grand Canyon Tech
Grand Canyon Tech
