Panasonic KXDT333   Phone Logo
Posted on Sep 20, 2011
I'm trying to programme phone numbers that I use daily into the phone's memory (not the quick dial buttons on the right). The instructions in the quick reference guide don't seem to work ( at least for me). Plus, it only explains how to porgamme a phone number to a 2 digit number (i.e. HO's number could be number 11), but I only want to add them to the 'address book', if that's possible. Thanks for any help!!
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Sep 20, 2011
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
2332
Points
79
For this problem contact the mobile service provider....
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
Cordless phone GE model 2-9635 Instructions to program speed dial
After a lot of research, I have found that GE has handed the phones and their manuals down to a company called "ThomsonTM" And if you come across any of problems for this phone in the future, I'll give you their phone number so you can still get help, at: 1-800-447-1700
Otherwise for help right now for the speed dial issue, I could only find directions that were of general use of multiple GE Cordless Phones, so it's worth a shot if you've got the time, otherwise, I suggest calling the number above.
Here is goes:
1.)Raise the phones reciever, or push the "Power/On" button.
2.)Press the "Store" button.
3.)Press the number 0 through 9 or a quick dial letter A, B, C,... to assign, then press the "Store" Button again to confirm the entry.
4.)Enter the number you want to assign the speed dials memory location, and press "Store".
5.)If your GE Phone prompts you to enter a Contact Name, use the keypad to enter it. Press the "Skip" button to enter a space, and the "Store" button to confirm your entry once again.
Once again, this is just a generalized GE Cordless phone guide, and may not be exact to your phone, in which I further suggest calling the electronic product's helpline by
ThomsonTM at:
1-800-447-1700 begin_of_the_skype_highlighting
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Would you please be able to tell me how to programme a number in this phone.... on a specific button down the side.
What happens when you dial "9" on the intercom? If you get an outside line, then your phone is programmed properly. If you get an empty line, then you need to disable vacant lines in system program 400.
To program the right side buttons for speed dial, press PROGRAM a button on the right side, and dial 9+ the number as you would dial it on an outside line, then STORE.
On the left side, a waste if you're putting speed dial number sin, you dial 29 instead of 9, but normally you reserve them for lines, extensions, and features that require lit buttons. The codes would begin with 0,1 and whatever the magic code for the features are.
Carl
I am trying to store numbers in my old 21 memory GE corded phone (Model No.2-9167A) Can you help me? Thank you.
Try this link:
http://www.home-electronics.net/USER-GUIDES/29169_DOM_EN_CD_IB.pdf
It's for a different model (2-9169), but I was able to store a number on my 2-9167A from these instructions. You'll have to lift off the plastic cover on the right side to be able to press the "Store" button - but you probably know that. Also, if you actually want to store more than 9 numbers (not counting the A, B & C buttons), then you'll use 01 thru 09 when storing or dialing. Good luck!
7helpful
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
3answers
Programming a number for memory
Memory
21helpful
4answers
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
