20 Most Recent Panasonic KX-T7431 Corded Phone Questions & Answers
How to display time instead of Ring Off?
You can search for desired items by using the Jog Dial on the corresponding display menu. Rotate the Jog Dial in either direction as desired. The items will be displayed as follows. There will be seven displays.
4/2/2015 8:00:41 PM • Panasonic... • Answered on Apr 02, 2015
2answers
HOW IS THE CLOCK TIME CHANGED ON A KX-T7431 PHONE
From the phone connected to the first jack (usually ext 101) press PROGRAM and dial **1234. If it's successful, you'll see SYS PGM? or similar language. Dial 000 and press SP PH. You should see the date. Press FWD until the time displays. Key in the new time and press STORE to save.
PROGRAM or pick up the handset and drop it back down will get you out of programming.
Carl
10/16/2014 10:19:14 PM • Panasonic... • Answered on Oct 16, 2014
My panasonic kx-t7431 message light won't light up, I have voicemails but it will not light up, please help!
With the headset off, push the intercomm button or SP-PHONE button, then once you hear the speaker is on do do this.Push the STAR sign which is * and then number 700 and your four digit extension.For example ( *7000422).
8/5/2014 3:13:56 PM • Panasonic... • Answered on Aug 05, 2014
Need VM passcode reset
Search it on panasonic.com
5/26/2014 3:20:31 PM • Panasonic... • Answered on May 26, 2014
CO Not Assigned - unable to select and outside line
Did you not assign a speed dial CO buttton to an extension
3/12/2014 1:02:26 PM • Panasonic... • Answered on Mar 12, 2014
Problem with extension and voicemail
1. Can be done but you have to have installer access to the system. You could also move the extensions at the phone system.
2. Is his call forwarding set (720x 165 #)? 720 sets forwarding for both intercom and outside calls.
1/17/2014 11:16:36 PM • Panasonic... • Answered on Jan 17, 2014
0answers
Panasonic KX-T7431 Corded Phone Logo
145 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
turn off message light
  • Lands Phones
