SOURCE: Hi I have a Central Pneumatic model 94667 air
On this particular issue, I agree with trpabc, given the description; you most likely need a new pressure switch. It's unlikely that it suddenly got out of adjustment, therefore a new one is in order.
nobody794:
I had the same issue you had, and after reading your post, I went down to my garage to investigate... Turns out the valves in the compressor are just simple reed valves, like on a 2-cycle engine, and my inlet valve had some gunk baked on it, which didn't allow it to shut all the way, giving me only 60 PSI. I cleaned all the parts with a wire brush, then polished the surfaces with 1000 grit sandpaper, and it runs like a new one again. :o) I don't think you can actually crack those thin sheets of metal...
