20 Most Recent
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Questions & Answers
What is the difference between a Dewalt D55151
There is no point asking. If your spare part is also type 1 or type 3 compatible then who cares? In case you find a spare part that is only compatible to the type 3 machine and yours is type 1 then you should find the type 1 one because this is only compatible with your machine because that spare part is not a part of the type 1 machine.
I have a Dewalt Emglo
My copy/paste/hyperlink skills are not working.
There is a dipstck directly up from the oil drain plug.
Why wont the motor kick in and set off the reset button
The circuit breaker is to protect your compressor most times the its a problem by to less oil inside because of fall over during transport or operate with the powerplug instead of the pressure switch.
Than it has no pressure release and can not come to turned round
he needs to blow off by pressostat (pressure switch)before it can free start , BUT it can also happens that your capacitor is broken then there is no start direction and then there is also no start only humming sound
Thermalcutout
The start capacitor on the motor is bad. Replace it and it will stop activating the thermal cut out.
I have an Emglo compressor which firers up without
If the in-tank check valve is leaking air back into discharge line from the pump, the motor will not have enough power to overcome headpressure. Easy test with some air in the tank. Remove the discharge hose at the brass check valve at tank. Spray soapy water on valve to test for leak. If leaking remove the valve and clean the seat or replace as needed (drain air from tank before you remove the valve). If no leak at the valve, test the capacitor(should read to within 95% of mfd rating). Good luck
Can i substitute common motor
Dewalt claims that motor oil will cause carbon deposits to form on piston/cylinder head and on the inside of the discharge tube. I see carbon deposits on most all compressors that come in for repair. The carbon is not reason for repair. Usually forgot to add any oil causing rod failure. I believe that most compressor oils are just mineral oil. If the climate in your area is moderate, and you do not use the unit for 8 hours a day, motor oil will work just fine. The crank is steel and the piston rod is made of aluminum (no bearing shell). What makes the unit last longer is change the oil more often (holds very little oil). Good luck
