20 Most Recent Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer Questions & Answers
2answers
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
12/26/2020 9:50:30 PM • Dewalt DC616kn... • Answered on Dec 26, 2020
Motor doesn't run, but light remains steady
There are two possiblilites. One is that the switch is broken (the electrical part of it has failed) and the other is that the motor is broken. Usually is the first based on my experience.
1/6/2019 4:49:43 PM • Dewalt DC616kn... • Answered on Jan 06, 2019
5answers
Dewalt dc618 nailer is not firing
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
12/5/2018 12:44:39 PM • Dewalt DC616kn... • Answered on Dec 05, 2018
When i put the battery
Four flashes is a low battery, multiple flashes indicates a jam.
It may be hard to see - or the driver is stuck. Remove all nails and check again - see silver? It's either the driver (push it back up) or a nail (remove it with pliers.)
8/13/2015 5:37:47 AM • Dewalt DC616kn... • Answered on Aug 13, 2015
0answers
2answers
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
8/2/2010 1:29:17 AM • Dewalt DC616kn... • Answered on Aug 02, 2010
Dewalt cordless nail gun fires but doesn't seem to
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
11/25/2009 4:56:46 AM • Dewalt DC616kn... • Answered on Nov 25, 2009
I have a Dewalt D55166 air compressor that doesn't work when I pull up the button. Where do you suggest I start to troubleshoot this issue? It worked just fine a week ago.
https://support.dewalt.com/hc/en-us/articles/360017799818-Why-won-t-my-compressor-power-on-
1/6/2024 10:40:37 PM • Dewalt Air Tools... • Answered on Jan 06, 2024
Does a Dewalt D55166 air compressor have a reset button?..
It has a pressure valve, that's all.
1/6/2024 12:48:32 PM • Dewalt Air Tools... • Answered on Jan 06, 2024
2answers
Dewalt D55146 air compressor almost immediately shuts down
I was facing this exact same issue. My dewalt compressor was spitting milky oil, and then suddenly stopped working but then I found this troubleshooting guide which really solved my issue: https://aircompressorinsider.com/air-compressor-problems-and-solutions/ Your mentioned issues were at somewhere around number 60-65, I dont exactly remember it now :)
7/21/2023 10:20:01 AM • Dewalt Air Tools... • Answered on Jul 21, 2023
My Dewalt 15 gal D55168 air compressor will not continuously build air after air supply has been depleted. Please provide help or a service center close by. I live in NW Oklahoma. Thank you.
you may be using more air that unit can supply. This is a very common error. it is only 5 cfm which is small. Call Whitton Supply Co. or visit our local Oklahoma City showroom (405) 236-5561.
5/12/2023 6:22:12 PM • Dewalt Air Tools... • Answered on May 12, 2023
Where is the reset button on a dewalt 20v air compressor?
there is not one.
2/8/2022 4:39:43 PM • Dewalt Air Tools... • Answered on Feb 08, 2022
My dewalt 15 gal D55168 runs momentarily then trips the GFI outlet.
There is a ground fault in that case. If you are in need to ask this sort of question, I recommend the services of a qualified electrician.
8/26/2021 12:51:48 PM • Dewalt Air Tools... • Answered on Aug 26, 2021
Where is the reset button on a Dewalt D55146 air compressor?
THERE IS NONE
3/26/2021 7:15:06 PM • Dewalt Air Tools... • Answered on Mar 26, 2021
I need to find the reset button on a D55146 Dewalt air compressor
There is no reset button for the compressor, if the compressor won't start check the valve is not open, also check the outlet power, Shut the drain valve at the bottom of the tank if it's open
3/26/2021 6:56:39 PM • Dewalt Air Tools... • Answered on Mar 26, 2021
Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer Logo
14 questions posted
Top Dewalt Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Air Tools & Compressors
Most Popular Question
dewalt dc618 nailer not firing
  • Air Tools & Compressors
