20 Most Recent
Kyocera Copystar CS-1620 Black and White Copier Questions & Answers
Error code j00 flashing
Open the drawer and left cover and check for any misfed paper. there is probably a small piece of paper jammed in a sensor actuator.
My kyocera 1635 copy shows c6000 error i need a code to cancle it
u cannot clear it if it is c600... if is c6400, u can fix it by entering mtce mode: press 1,0,8,7,1,0,8,7 in sequence after switch ON; u get "U" ,, now enter 1, 6, 3... press enter/start; cle appears; press enter/start; u get the machine ready now. if c600 fuser lamp might be blown, needs replace; first try as above.
ERROR CODE C6000 ON OLIVETTI D-COPIER 200MF
C6000 is usually cause by fluctuation of current(power supply).STEP 1:Open top cover then turn ON the machine,press System Menu then scroll down to Service Setting,then HOLD BOTH the "Start key" and "#" and press "OK".Scroll down to Maintenance Mode then press "OK".press 163 on the keypadscroll down to "Execute" press "OK"Turn Off/On...If C6000 appears again..,STEP 2:U have to reset the fuser thermostat manually.FUSER REMOVAL:Remove rear cover,top cover,left and right cover.Remove two screws. Unplug two connectors. Pull out Fuser unit.Thermostat removal:remove two screws,separate the upper part from the lower part,,remove separation claws (3pcs each 1 held w/ screws at the rear)remove the heater lamp,and upper fuser roller...remove two screws that held the thermostat (circular shape)(reset manually)If you touch the top of the thermostat you will notice that it is in concave form...,you have to drop it hard on the flat surface in order to bring back it\'s original form which is CONVEX.DO THE REVERSE ORDER TO ASSEMBLE.THEN,Repeat procedure in STEP 1.
How to reset the unit...
press and hold the following buttons in the sequence below.
(1) Stop/clear, (2) start, (3) exposure lighter, (4) exposure darker, release the 4 buttons and press the stop/clear button again. the display should now indicate 000.
below the display are 3 buttons... press the left button once, the middle button 6 times, and the button on the right 3 times. the display should now indicate 163.... press the start button 3 times.
your machine will now restart, and if the code was as a result of a power problem, should now work fine. if not the problem could be related to the fixing unit, power supply, or one of the boards.
Also do not tamper with any settings while in the service mode, this WILL have undesired effects. TAKE NOTE, this will only work if your model is the KM-1500
