20 Most Recent Olympus FE-190 Digital Camera Questions & Answers
3answers
Pictures are blurry and out of focus
If you've followed all stpes to take a good photo and all you get is a blurred image, you can't really do anything else. Your Olympus Digital Camera is quite complex device and I don't believe it you can repair it yoursef. Look for an authorized repair store, ask for a diagnosis and decide if it can be or is worth to be repaired. You can buy a used one in perfect conditons for about 39 USD Olympus FE 190 6MP Digital Camera with Digital Image Stabilized 3x Optical... or for 27 $ for ebay
12/27/2015 1:32:51 PM • Olympus FE-190... • Answered on Dec 27, 2015
2answers
Horizontal lines in pictures
hi If u find that the lines are vertical that is often a result of taking pictures of very bright subjects. This is  called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician , and they will send it out to have it looked at. hope this helps!
thank u rate me!!!
3/3/2015 7:46:56 PM • Olympus FE-190... • Answered on Mar 03, 2015
How do I clean the battery contacts
The best way to clean battery contacts, is using a rubber eraser (for pencils). Rub it gently to the contacts, try battery first and do camera then if no result. I have used a file on stubborn contacts, but there is a chance you can do harm to the contacts, so be very careful. If this don't work, try another battery. Else, go to the shop to have them look at it. Good luck! :)
4/17/2014 5:47:23 AM • Olympus FE-190... • Answered on Apr 17, 2014
2answers
CARD SETUP that contains only two options 1. power off 2. format
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or lost. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images or corrupted.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
12/20/2013 5:37:34 AM • Olympus FE-190... • Answered on Dec 20, 2013
2answers
Pictures were on memory card, i was looking
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
11/12/2013 1:56:04 AM • Olympus FE-190... • Answered on Nov 12, 2013
3answers
Some of my photos in olympus master just
In this case you should try some photo recovery software to see if you can recover the lost photos, here are some programs you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Note: Before your pictures are recovered, do not attempt to save more files to the Olympus memory card in case the original files(your photos) are overwritten.
9/9/2013 2:10:21 AM • Olympus FE-190... • Answered on Sep 09, 2013
manual
3answers
My Olympus T-100 camera is showing writing protect
can mean that the memory card is locked. take out the memory card and check for a lock slide at the sides of the card that you can adjust to a lock and unlock position, then test the card again.
5/8/2013 2:04:29 PM • Olympus FE-190... • Answered on May 08, 2013
How to fix write protect
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
4/24/2013 4:22:20 PM • Olympus FE-190... • Answered on Apr 24, 2013
How do I turn off the flash on my Olympus FE-190?
Press cursor-right (marked with a lightning bolt), then select the desired flash mode. To turn the flash off, select the lightning bolt in a circle with a slash through it.Full details are on page 17 of the Advanced Manual. If you need a manual, you may download a copy from here.
12/22/2012 3:33:36 PM • Olympus FE-190... • Answered on Dec 22, 2012
2answers
Any service centre in kerala state , india
Look HERE for a list of all authorized service centers in India. Unfortunately, it seems like there's none in Kerala.
There is a showroom though.
7/25/2012 12:42:52 PM • Olympus FE-190... • Answered on Jul 25, 2012
When i switch on my digital camera write protect message is displayed on it , my camera is olympus fe-190
If your camera uses a SD memory card then the write protect switch maybe on.SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
5/7/2012 6:41:59 AM • Olympus FE-190... • Answered on May 07, 2012
I need to download my
with cable connect and restar computer, or get driver in cd olympus
9/13/2011 4:50:35 PM • Olympus FE-190... • Answered on Sep 13, 2011
Need the software to download
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery and Picasa ( http://picasa.google.com ) on Windows.
9/13/2011 4:42:02 PM • Olympus FE-190... • Answered on Sep 13, 2011
Card set up message comes up at power on. select
Seems like the card has become corrupt. There is one thing you could do before replacing the card. SD cards have a small yellow switch with a sign to 'lock' the card. Make sure that the switch is not in the 'lock' position. Then clean the contacts with a pencil eraser and try to access or format the card again. If it fails to solve the issue, then try using another memory card.
8/31/2011 11:04:40 AM • Olympus FE-190... • Answered on Aug 31, 2011
Olympus FE-190 Digital Camera Logo
153 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
olympus t 100 camera showing writing
  • Cameras
