20 Most Recent Gemini Sound Products DJM-1 Microphone Questions & Answers
Gemini djm-1 gooseneck microphone repair question
No problem! 2=RED 3=Black 1=White The wire without a color is ground. It can be soldered to pin 1 if necessary. Hope this helps.
12/17/2008 12:10:47 AM • Gemini Sound... • Answered on Dec 17, 2008
I have a used Gemini turntable DJQ-1500 that is spinning extremely slow and is laggy when manually adjusting the record
Clean Your Turntable with a microfibre cloth. Power off the turntable and unplug it for safety. Access the turntable's platter by lifting it off. Inspect the belt. If it's loose or damaged, consider replacing it. Amazon should have the belt replacements. If Your Record Player Spins Too Slow, Here's How to Fix It in 3 Steps - All For Turntables
4/18/2024 5:02:37 AM • Gemini Audio... • Answered on Apr 18, 2024
Both draws will not open on my Gemini CDX 602. What is the best thing to try
It is strange that both won't open, something common to both, power supply to them? https://www.google.com/search?q=gemini+cdx+602+drawers+won%27t+open ..
11/29/2022 5:39:07 PM • Gemini Audio... • Answered on Nov 29, 2022
The output of my GEMINI GVX-SUB18P is weak and distorted. Also I measured the Voltages Ubase and Uemitter on the output transistors and both are the same: 0.40 Volt DC.
measuring that voltage wont tell you a lot of information. You need to see signals in an audio circuit and those transistors could be MOSFET and or they cannot be tested while in circuit.
5/23/2020 4:07:07 PM • Gemini Audio... • Answered on May 23, 2020
Hi everyone, I have a Gemini PT 2000 and it's sound is noisy. Moving the tonearm sometimes sounds ok, sometimes sounds worst. The 45 rpm button isn't working, the pitch adj. isn't well calibrated, the tonearm holder (the plastic clip) is broken and the power button light shielding (the transparent or almost transparent plastic is broken in half). Some advices in order to restore the turn table?
Much depends on the noise and where it is originating. The deck doesn't seem well thought of and it is unlikely the manufacturer has a spare parts service - unless you have the skills needed to locate and rectify the "noise", which could be electrical, electronic or mechanical, and otherwise restore the deck it would seem advisable to replace it.
7/16/2018 6:31:37 PM • Gemini Audio... • Answered on Jul 16, 2018
Where do I get a Gemini xl200 cartridge and stylus from as my two decks didn't come with them
Sorry we have no way to know were you are so how can we recommend a place to buy it?
4/21/2017 9:29:54 PM • Gemini Audio... • Answered on Apr 21, 2017
Gemini Sound Products DJM-1 Microphone Logo
1 questions posted
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Audio Players & Recorders
Most Popular Question
gemini djm 1 gooseneck microphone repair
  • Audio Players & Recorders
