20 Most Recent Gemini PT-1000 II Turntable Questions & Answers
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
12/19/2013 12:41:05 AM • Gemini PT-1000... • Answered on Dec 19, 2013
0answers
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself. For the manual visit the Gemini website.
5/19/2013 8:48:53 PM • Gemini PT-1000... • Answered on May 19, 2013
0answers
I need to replace the
There should be a number on the cartridge, put that into google and that should answer your question. If you need a cartridge you can generally use any that will fit the headshell, as long it is a magnetic cartridge. It will depend on how much you want to spend for the best quality.
6/26/2011 4:32:28 PM • Gemini PT-1000... • Answered on Jun 26, 2011
I plugged my gemini pt-1000 turntable into the aux
If the amp doesn't have an imput marked phono, or deck, or turntable, the answer is yes. Search for a 'magnetic cartridge pre-amp' via google.
2/28/2011 7:40:42 PM • Gemini PT-1000... • Answered on Feb 28, 2011
Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
1/20/2009 3:29:56 PM • Gemini PT-1000... • Answered on Jan 20, 2009
I have a used Gemini turntable DJQ-1500 that is spinning extremely slow and is laggy when manually adjusting the record
Clean Your Turntable with a microfibre cloth. Power off the turntable and unplug it for safety. Access the turntable's platter by lifting it off. Inspect the belt. If it's loose or damaged, consider replacing it. Amazon should have the belt replacements. If Your Record Player Spins Too Slow, Here's How to Fix It in 3 Steps - All For Turntables
4/18/2024 5:02:37 AM • Gemini Audio... • Answered on Apr 18, 2024
Both draws will not open on my Gemini CDX 602. What is the best thing to try
It is strange that both won't open, something common to both, power supply to them? https://www.google.com/search?q=gemini+cdx+602+drawers+won%27t+open ..
11/29/2022 5:39:07 PM • Gemini Audio... • Answered on Nov 29, 2022
The output of my GEMINI GVX-SUB18P is weak and distorted. Also I measured the Voltages Ubase and Uemitter on the output transistors and both are the same: 0.40 Volt DC.
measuring that voltage wont tell you a lot of information. You need to see signals in an audio circuit and those transistors could be MOSFET and or they cannot be tested while in circuit.
5/23/2020 4:07:07 PM • Gemini Audio... • Answered on May 23, 2020
Hi everyone, I have a Gemini PT 2000 and it's sound is noisy. Moving the tonearm sometimes sounds ok, sometimes sounds worst. The 45 rpm button isn't working, the pitch adj. isn't well calibrated, the tonearm holder (the plastic clip) is broken and the power button light shielding (the transparent or almost transparent plastic is broken in half). Some advices in order to restore the turn table?
Much depends on the noise and where it is originating. The deck doesn't seem well thought of and it is unlikely the manufacturer has a spare parts service - unless you have the skills needed to locate and rectify the "noise", which could be electrical, electronic or mechanical, and otherwise restore the deck it would seem advisable to replace it.
7/16/2018 6:31:37 PM • Gemini Audio... • Answered on Jul 16, 2018
Gemini PT-1000 II Turntable Logo
Popular Tags
16 questions posted
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Audio Players & Recorders
Most Popular Question
direct drive spinning fast
  • Audio Players & Recorders
